Exporting custom fields/columns
Is there a way or could you have a way to customize what fields/columns you want to export. The reason I am asking is I mostly do use and been using it for a long while to edit my audio books and I was thinking that would be a nice feature to have when I create a library for it.
Thanks bunches,
Kitty Kat
PS Keep up the great work other wise. Machen Sie ansonsten mit der großartigen Arbeit weiter.
THe export scripts are plain text files that can be editted with any plain text editor.
When editting, you can add or remove the property and field references according to your needs.
See also the documentation:
