How can I get an Export to preserve international chars? Currently e.g.
folder name: Creaciones inolvidables con Podestá y Bermúdez
outputs
text file: Creaciones inolvidables con Podestá y Bermúdez
Thanks.
outputs
Thanks.
By default the export makes utf-8 encoded files which covers all unicode characters.
Your outputs indicates that the file is utf-8 encoded but the program you use doesn't detect it or can't display it.
Do you know if your program can read unicode text files?
In "Options > Export" do you have "[x] Export file with BOM" checked? This makes it easier to detect the encoding of a file.
That fits. Any idea where I can change from that default?
In general, no - sorry not to ask more clearly.
For avoidance of doubt, I want output equivalent to the result of copy'n'paste from Explorer to Notepad. I.e. no conversion by mp3tag.
Thanks, Dano.
You can use the $filename() function to define the encoding.
For your case you choose ansi as second parameter which means your system codepage.
$filename(test.txt,ansi)
Ah, how careless of me not to see that in the Help. Thanks, Dano.
Note to others: to specify just encoding avoiding "Select export file" (sic - really "Select export config") overwriting manually inputted "Export file name:" value, make the filename a null string!
