Hi everybody, stupid question incoming.
I recently put an ssd in my Ipod classic and flashed it with Rockbox everything works fine except for the ratings, which i write into the id3 tag with Winamp.
There currently doesn't really seem to be a way for Rockbox to use these ratings instead it uses its own system and i really don't fancy having to manage and sync two different rating systems.
It seems a lot easier to just create a playlist per artist that grabs everything with a rating over 3 and trow that on my Ipod and i can update the playlists every once in a while from my pc.
I guess i can figure out how to churn out a playlist and i can sort my database in mp3tag by rating but i cant seem to get playlists separated by artist which kind of negates the purpose.
i store my stuff like this "D:\My Documents\My Music\artist\album" where double albums just get appended with a CD1/2/3 etc on the album level. Any compilation albums shouldn't be a problem because the artist field is the same as the album field and the actual artist name is put in front of the title but other than that all the tags are normal.
I did a search through the forum and there are some people with similar questions regarding playlist but to be honest the scripts that get discussed kind of go over my head.
So my question is can i create the playlist like i want and how would i go about doing it?
