Hello
The only i wish to know in on how can i export sorted :
Filename -Path- Title - Artist -Album name
it does not matter if the path is in the 2nd column or 4th ut is imporatnt to be inlcuded in the resulted table . There is a big chaos otherwise
The subdcirectories are not included !!! How can thy be added ?
Usually, the _DRIECTORY is part of _PATH. But, naturally, you can include _DRECTORY.
Which result do you expect that is no
What have you tried so far?
Right-click on a column header.
Select Columns ...
In the following dialogue
either check if there is already an entry for _PATH and activate that one in the left list or
create a new column with the "New" button.
Fill in the fields as shown in the screendump:
Value: %_path%
(Field: stays empty)
If you only want to see the _DRIECTORY and not the full _PATH, use %_directory% instead of %_path%
See whether you like the position of the new field and if not, move it with the buttons for up or down to the preferred position.
Click OK to save the changes.
You may now sort by this column
Then please show me the export script with which you want to export the path.
(And please upload pictures to the post instead of to an external hoster)
$filename(html,utf-8)<?xml version="1.0" encoding="utf-8"?>
Mp3tag - File OverviewMp3tag - File Overview
%_date%
$loop(%_filename_ext%)
<td$if($odd(%_counter%), class="odd",)>$replace(%title%,&,&)
<td$if($odd(%_counter%), class="odd",)>$replace(%artist%,&,&)
<td$if($odd(%_counter%), class="odd",)>$replace(%album%,&,&)
<td$if($odd(%_counter%), class="odd",)>$replace(%track%,&,&)
<td$if($odd(%_counter%), class="odd",)>$replace(%year%,&,&)
<td$if($odd(%_counter%), class="odd",)>$replace(%genre%,&,&)
<td$if($odd(%_counter%), class="odd",)>$replace(%_filename_ext%,&,&)
$loopend()
</table>
<p>built on %_date% with %_app% - the universal Tag Editor <a href="http://www.mp3tag.de/en/" title="Mp3tag Website">www.mp3tag.de</a></p>
| Title | Artist | Album | Track | Year | Genre | Filename |
You could replace
with
$loop(%_path%)
<tr>
<th class="title">Title</th>
<th class="title">Artist</th>
<th class="title">Album</th>
<th class="title">Track</th>
<th class="title">Year</th>
<th class="title">Genre</th>
<th class="title">Filename</th>
<td$if($odd(%_counter%), class="odd",)>$replace(%title%,&,&)</td>
<td$if($odd(%_counter%), class="odd",)>$replace(%artist%,&,&)</td>
<td$if($odd(%_counter%), class="odd",)>$replace(%album%,&,&)</td>
<td$if($odd(%_counter%), class="odd",)>$replace(%track%,&,&)</td>
<td$if($odd(%_counter%), class="odd",)>$replace(%year%,&,&)</td>
<td$if($odd(%_counter%), class="odd",)>$replace(%genre%,&,&)</td>
<td$if($odd(%_counter%), class="odd",)>$replace(%_filename_ext%,&,&)</td>
</tr>
$loopend()
<built on %_date% with %_app% - the universal Tag Editor <a href="http://www.mp3tag.de/en/" title="Mp3tag Website">www.mp3tag.de</a></p>
... and insert
<th class="title">Path</th>
before
and also insert
<td$if($odd(%_counter%), class="odd",)>$replace(%_path%,&,&)</td>
before
I can see %_path%% where it should be %_path%.
I don't quite understand what
means.
And there is no need to yell at me with
What did you expect the output should look like?
I expected an extra column with the contents of _PATH, being sorted by _PATH
Please use the forum upload function for you screenshots. There is absolutely no need to use an external hoster.
Also, if the script does not work as expected, I would like to see the whole script as that is responsible for the output.
And the script should be issued as text and not as a picture as that would make testing much easier.
here is the code file
Please use the upload function in the forum.
If that is the updated mte-file then I do not see any updates whatsoever.
I still see %_filename_ext% as loop variable and I do not see any of the suggested lines that need to be added for more output.
Please adapt the script and try again.
html_standard.mte (2.0 KB)
I cannot understand I applied many times the updates loaded this file so amny times in my test editor and still showing different result in you?
