Hi, Ive installed the new 64 bit version, its been a while since I used the product.
I can see the mixartist field in the extended field list and can add this to the tag view - Ctrl Q but cannot figure out to add it to the column view as it does not show in the list to add? I cannot see the extended fields in the list to show? How do I add to the column view...Thanks
