jistme
1
Is MP3Tag capable of extracting a certain part of a tag, and copy it to another tag?
I have titles such as:
Cello Sonata No.1 in E minor, Op.38 › I. Allegro non troppo
I want the part before ' › ' to be copied in a custom tag named 'Composition',
and the part after ' › ' copied to a custom tag named 'Movement'.
So 'Composition' tag becomes: Cello Sonata No.1 in E minor, Op.38
and 'Movement' tag becomes: I. Allegro non troppo
(title tag is not to be changed)
I found an action called "split field by seperator", but I think this can only split to multiple fields in the same tag?
tia!
Yes, that's a main feature of Mp3tag.
Create an action (quick at once or permanent) ...
Begin Action Group Test_2012#20120626.jistme.Guess
Action #1
Actiontype 7: Import tag fields (guess values)
Source format __: %TITLE%
Guessing pattern: %COMPOSITION% › %MOVEMENT%
End Action Group Test_2012#20120626.jistme.Guess (1 Action)
DD.20120626.1210.CEST
Begin Action Group _Script Test#TEST
Action #1
Source format __: %title%
Guessing pattern: %composition% › %movement%
End Action Group _Script Test#TEST (1 Action)
jistme
4
Fantastic!
(so I just should have been searching for 'import' instead of 'export'
Thanks guys!
This worked great for me too
MP3Tag what a fantastic program
Thanks
Ian
