Extracting a variable
I'm trying to repair hundreds of track id's after program i trialled messed stuff up.
Basically i'm wanting to create an action to extract var3 from the example below and write it back into "BEATPORT_TRACK_ID"
https://www.beatport.com/%var1%/%var%2/%var3%
Thanks.
Try an action of the type "Guess value" for the source field
Target: https://www.beatport.com/%dummy%/%dummy%/%BEATPORT_TRACK_ID%
Thank you very much that fixes it.:slightly_smiling_face::+1:
