Extracting multiple images at the same time with multiple audio files, is it possible?
Here is my problem, I would like to extract 3 images from my audio files at the same time...
It says: Cover varies
And I can't do anything...
Ideas friends...
Use an action of the type "Export cover to file" with a pattern for
Filename that produces unique filenames e.g. like this:
Format string: %title%_%_cover_type%
  1. Select the 3 song tracks in the File List
  2. Then select the menu "Actions" -> Actions Quick -> "Export cover to file" -> choose a unique filename for every of this 3 cover images with a mask like %_FILENAME% (this would create one cover image per track - even if it is the same cover art) or choose some other mask like %ARTIST% - %TITLE% - %ALBUM%, depending on whatever you have filled in your ID3 tags.
  3. Press the OK Button
The extension for the cover will automatically be set (like .jpg or .png)
You will find the extracted covers at the same place as your songs.
You can not export multiple covers in the GUI. You can only export a cover that you can see in the GUI.
A big thank you to ohrenkino and LyricsLover, you are always there to help us...
Your methods work...
For the images of my BSI Simian, I chose this command:
%artist%-%album%
and my 3 images were extracted at the same time with the right data...
Great thanks guys :wink: :+1:
Please be aware that you only get 3 different cover images if your ARTIST and ALBUM are unique per track. You only get 1 cover (the last one) if you have the same ARTIST and same ALBUM on all 3 tracks!
Thank you LyricsLover for this info... :+1:
