hopefully this is the right place to post this question.
I tried 2.42d, upgrade install from 2.42c. my 2.42c build was working fine.
upon trying to read any mp3 file tags, it is significantly slower. a folder of 20-30 tracks takes 15-20 seconds or more to read in. 2.42c was 1 second or less.
additionally, it appears 2.42d has something wrong with the Length (%_length%), Codec (%_codec%), Bitrate (%_bitrate% kBit/s) and Frequency (%_samplerate% Hz) columns.
i did try the horizontal tag panel and that definitely looks promising and useful.
any ideas if it's a build problem or just something I'm doing wrong?
