Eli
March 27, 2006, 4:13pm
1
Mp3tag v2.35l - 27.03.2006 - 12:52:44
OS-Version: Windows XP Service Pack 1 (Build 2600)
Build: Mar 18 2006 14:41:47
AppPath: 498.958.336 Bytes frei (D:\Program Files\MP3 Ripping\MP3Tag\)
DataPath: 706.674.688 Bytes frei (C:\Documents and Settings\********\Application Data\Mp3tag\data\)
TempPath: 706.674.688 Bytes frei (C:\DOCUME~1\******~1\LOCALS~1\Temp\Mp3tag v2.35l\)
CATCH
File: .\mtdirectoryreader.cpp
Line: 309
I have been unable to try the latest build to see if the old error was fixed as I keep getting this error.
Can you please verify with 2.35m?
Edit: In case you get the error again, please start Mp3tag with the /FLOG1 parameter. There'll be a file called Mp3tagLog.txt or Mp3tagLog.zip at %APPDATA%\Mp3tag<!--fontc--> after the crash which I'd need for debugging.
Eli
March 29, 2006, 11:50pm
3
Mp3tag v2.35m - 29.03.2006 - 11:07:57
Build: Mar 26 2006 15:21:38
AppPath: 492.154.880 Bytes frei (D:\Program Files\MP3 Ripping\MP3Tag\)
DataPath: 674.066.432 Bytes frei (C:\Documents and Settings\******\Application Data\Mp3tag\data\)
TempPath: 674.066.432 Bytes frei (C:\DOCUME~1\******~1\LOCALS~1\Temp\Mp3tag v2.35m\)
THROW
File: .\smetadatapicture.cpp
Line: 49
THROW
File: .\smetadata.cpp
Line: 107
CATCH
File: .\mtmainframethreads.cpp
Line: 801
Where can I upload the zip file? I assume you dont want the Mp3tagLog.txt as its 200mb (zip is about 6).
Also, after this error, I cant get mp3tag to close. Task manager says its still running... I really dont want to loose a bunch of tags again.
You can send the zip via email .
Florian
Closed
December 28, 2018, 1:52pm
6
