When traversing menu in 2.38 using (at least some) screen readers, no menu label is spoken/shown on Braille displays. This is quite uncommon, since menus usually pose no problem for assistive technologies. You can try it with Windows Narrator and/or NVDA.
This issue has been fixed with the current Development Build.
Thanks for reporting!
Kind regards,
Florian
