[F] Build 2.27e crashes before options dialogue
Hi Florian,
here's another bug report for a bug that I discovered right after installing the new Mp3tag Developer Build 2.27e: After clicking on 'File -> Options ...' the options dialogue does not show up. Instead I receive the following message box:
http://people.freenet.de/le.petit-prince/f...mp3tag_bug1.jpg
I can then go on to use Mp3tag; it does not quit, but does not show the options dialogue, either.
Here - as requested by the application - the file Mp3tagError.log from the 'Application data'-folder:
Mp3tag V.2.27e - 19.01.2005 - 00:39:11
OS-Version: Windows XP Service Pack 2 (Build 2600)
Build: Jan 16 2005 20:46:12
AppPath: 7.000.817.664 Bytes frei (C:\Programme\Heidenreich\Mp3tag)
DataPath: 7.000.817.664 Bytes frei (C:\Dokumente und Einstellungen\Administrator\Anwendungsdaten\Mp3tag\data)
TempPath: 24.533.045.248 Bytes frei (D:\Temp\Mp3tag V.2.27e)
FileVersion mfc42.dll: 6.0.8665.0
ERROR
File: d:\dev\projects_dlg\soptionsdlg.cpp
Line: 542
Expression: _S_TRUE(bRetVal)
LastError: 00000000 Der Vorgang wurde erfolgreich beendet.
THROW
Line: 579
CATCH
Line: 331
Hope this helps. :slight_smile: - As always, thanks a lot! :slight_smile:
petit prince
Yes, I'm aware of this bug and will fix it to the next release. For now deleting dwOptionsDlgPage at HKEY_CURRENT_USER\Software\Moebius\Mp3tag\Settings via regedit.exe should solve the problem.
Best regards and thanks for your feedback!
~ Florian
It does indeed. :slight_smile: Thank you very much!
petit prince
This bug is fixed with the latest Development Build.
:slight_smile:
Thank you, you made an old man very happy. :wink: :slight_smile:
petit prince
