On the Changes page text is displayed with fixed font without any wrapping. And it makes reading it absolutely inconvenient (letters are less visible on "orange-ish" background, horizontal scrolling has be used)
I believe it would be much better if text was displayed like this:
... and it also seems reasonable to move older versions' changes into separate page - to make Changes page load faster and don't overwhelm user with the amount of changes
This page is generated and I don't feel like manually adjusting the wrapping on every new release. I've move the old changes to a separate page, thanks for the suggestion.
It won't look as "stylish" as on 2nd screenshot. But the horizontal scrollbar and readability problem will be eliminated.
P.S. I believe lines in plain text file could also be wrapped automatically (right margin = 80, continuation indentation = 20) upon "generation". But that's up to you of cause.
