Ctrl-C/Ctrl-X/Ctrl-V shortcuts for clipoard in fields of the tag panel don't work with 2.42h. Copy/Cut/Paste only possible with right mouse click context menu. Worked before in 2.42f
Christoph Sternberg
Christoph Sternberg
Christoph, thanks a lot for reporting!
I've just fixed it and made a silent update to the current Development Build.
Kind regards,
Florian
Yes, it works now, thanks
just stepped in to report the error ... and found it already reported and fixed!
thanks a lot to both of you! andreas
