I have been entering Billboard info into the comment tag of a library of Top 100 songs from 1955 to date. I have a seperate directory for each year.
I prepare the directory by selecting all and < blank > the comments.
I then enter info in the format xx-yy-zz where xx is peak position, yy is peak weeks, and zz is Top 40 ranking for the year. There are usually many more files in a directory than the top 40. Those other comments are left blank.
I have added a "$right(%comment%,2)" sort function to the comment column.
Sort results are almost correct but some items are out of sequence. I see blank comment items merged into the commented list and sometimes I see commented items mixed in with blank items.
View refresh, plus column resort down and up will eventually (normally) fix the order.
Not a huge problem for me as I eventually transfer the ranking info over to Track which does sort properly.
