OS: Vista 32-bit
Processor: Core 2 Duo E6750
RAM: 2GB
Version: 2.45a
Issue: Sometimes during heavy disk or CPU load, the context menu does not cause mp3tag to launch and fully populate all selected mp3's. When this happens, only one or two random items in the selection show up within mp3tag. Closing mp3tag and trying again will properly populate the list.
Yes, Florian, this seems to work, better to say it works seamless, now I can remove my user made entries from the registry, wherever this was, I have to remember, yeeeaars ago.
... but ...
For drives and folders the "Mp3tag" menu string is found in the top section of the context menu.
For files this newly entry is somewhere down in the (fifth section of my) file context menu.
Is it possible to have the "Mp3tag" menu string always at the same position for all different filesystem objects?
How can I define a shortcut, say "3", oh no this is already catched by "Pro 3" application, so will say "M" as I had it already used in my user defined menu entries?
Is it possible to change the shortcut key when at installation menu?
