Hello,
when I edit a tag in the tag panel, then (again) Ctrl-C/V/X act as one is used to in the Windows world.
But Ctrl-A does not mark the contents of the tag field, but all the songs in the list.
Bug or Feature???
Ciao,
Andreas
Hello,
Bug or Feature???
Ciao,
Andreas
It's difficult to decide but I'd call it a feature. Especially since moving to a tag field automatically selects its content.
Kind regards,
Florian
IMHO it is not logical.
When I enter the list of songs, Ctrl-A should mark all songs, when I enter a text field, Cntrl-A should mark the contents of the text field. This is a standard behaviour...
I am totally with you.
The standard editing functions have to take place where the focus is.
And further on - how often I cannot remember - while the last days when editing unsynced lyrics multiline textfields I got crazy about the weird logic on inserting a line break! Once I pressed the CarriageReturn/Enter button I was thrown out of the edit field! This behaviour is not logical.
While editing lines of text I want the look and feel of a text processor, and therefore a standard Enter should cause a standard linefeed/carriage return and not leaving the edit procedure.
Leaving the edit field by pressing Shift+Enter resp. Ctrl+Enter is the better intuitive logic!!!
Florian, please do follow the common standards for common user access.
DD.20090327.0043.CET
Yup, that would be nice.
I'm wondering for such a long time about this behaviour so it's a kind of Mp3Tag-Standard for me, but I forget it everytime I'm using Mp3tag again.
The New Line Issue...
Inside an Excel Cell you can insert text and create a New Line with "Alt+Enter".
Inside an HTML WYSIWYG you may take "Shift+Enter" to have a New Line instead of a new paragraph with "Enter".
Inside MS Outlook and there inside a bullet list "Enter" generates a new entry with bullet, and "Shift+Enter" makes a New Line staying inside the current bullet paragraph.
So: "Shift+Enter" or "Alt+Enter" is what you get used to in the MS world...
But Ctrl-a is only defined where the focus is...
Ciao,
Andreas
Just released Mp3tag v2.43 Now with more Ctrl+A in edit fields
