If I select say 30 files and do CTRL-Delete, Mp3tag does a straight Delete i.e. deletes from the list.
Rather than do the expected disc delete that shows the 'Confirm Multiple File Delete' dialog.
On say 3 files, it works fine.
Anyone else get this?
EDIT: Actually is sometimes fails in even one file - try starting at the top of the list, selecting one file and hitting CTRL-Del, then repeat. Here, about 1 in 10 fails, apparently at random.
