Since version 232 (including 2.32s) If there is text i.e a title that has has the bracket [ or ] the text is removed if edited within the field. If text is edited in the left side area the text stays in place. If you then edit or click the field the text disapears.
E.G Album Name before click in field: Dido Live [CD/DVD] Disc 2. After click in field: Dido Live Disc 2. (only tested with MP3's)
In MP3Tag 2.32 (before it became Unicode) it was possible to load a folder directly into MP3Tag when I DoubleClicked on a Media-File in Explorer. After It became Unicode, this feature get lost.
I would like to see this feature back. Please.
I think this has something to do with the default action for your media files. At the moment files are passed after the /fp: command line argument (like the right click menu item does).
