$eql() function is case-insensitive despite Mp3tag help file claims it "returns true, if x equals y".
Mp3tag lacks case-sensitive boolean function for verifying equality of two strings. At the moment, one must resort to using regular expressions.
E.g.
$if($eql(a,A),x,y)
returns x
There's also $strcmp() function (same name as in foobar2000) but it seems to be just an alias of $eql() in spite of being case-sensitive in foobar.
According to help file syntax of two applications "should be (almost) compatible"
Please change the behavior of $eql() function or provide us with another solution.
Yes, $strcmp and $stricmp work the same as $eql, but I do not see where these string comparing functions have been documented.
DD.20110607.1958.CEST
dano
June 7, 2011, 4:30pm
#3
I'd like a working $strcmp() function.
nan4k7
November 26, 2014, 10:34pm
#4
I know this is an old post but any chances of an advance with this? I also need a eql or similar function that is able to compare case sensitive values.
It is most annoying that the $eql() function actually reports false positives if the compared strings contain umlauts (äöü).
So, yes: this function does not perform in the expected way.
DetlevD
November 27, 2014, 5:14pm
#6
Hmm, this works for me ...
$if($eql('abc ä xyz','abc ä xyz'),'yes','no')' - '$if($eql('abc ä xyz','abc Ä xyz'),'yes','no')
Result : "yes - no"
DD.20141127.1913.CET
DetlevD:
Result : "yes - no"
Then there must be something wrong which I cannot identify - please see the description in this thread:
[F] $eql() scheint Schreibweise zu ignorieren
It may be that it works with string constants but for some inexplicable reason it does not work with variables and the $upper function.
Florian
December 13, 2014, 12:04pm
#8
This has been addressed with the latest version Mp3tag v2.66.
Kind regards
Florian
DetlevD:
Result : "yes - no"
Since Mp3tag v2.66 ...
this Formatstring ...
... gives the result "yes - yes".
and this Formatstring ...
$if($StrCmp('abc ä xyz','abc ä xyz'),'yes','no')' - '$if($StrCmp('abc ä xyz','abc Ä xyz'),'yes','no')
... gives the result "yes - no".
DD.20170519.1700.CEST
Florian
closed
December 28, 2018, 2:05pm
#10
