There is a bug relating to the export of tags into text files.
The bug only seems to occur on albums with 8 or less mp3 files. Exporting 9 or more doesn't produce this strange behaviour.
This is what happens: The first track gets appended to the bottom of the list, so when you import the file back as tags, well, you know know what happens.
Rammstein - Das Modell - Kokain - 2/3 - 1997 - Metal -
Rammstein - Das Modell - Alter Mann [Special Version] - 3/3 - 1997 - Metal -
Rammstein - Das Modell - Das Modell - 1/3 - 1997 - Metal -
Hope this helps. Mp3tag is still the best tagger on earth.
Thanks Florian. One other thing related to this topic. I modified the export template. Now I can export/write a template but can no longer import it back as tags. I'm totally confused now!!!
Okay, then you just have to use this format string to import it back to your files %artist% - %album% - %title% - %track% - %year% - %genre%
Hope that helps!
Florian
That's what I've been using Florian. It only stopped working after I reported this bug and then tried changing the template myself. I changed it back to the default template and now it exports to text, but will not import back as tags. Very strange indeed.....
