... text as required by the spec:
Instead it shows the first post-null string as a second tag of the same name.
E.g. see the attached.
This is very unlikely to be changed. ID3v2 is already a great mess and I refuse to support every bit of nonsense from this "spec".
The problem you're referring to is a different one. Mp3tag uses the 00 character to seperate multiple entries within text frames.
Kind regards,
Florian
