When I execute an action that renames a folder, Mp3tag renames and moves the first song, but then "doesn't notice" that the other files have been moved too, and I get this error for the rest (the first song is moved correctly).
Mp3tag v2.36f
File cannot be opened for writing.
Do you want to continue?
Yes No
The path indicated in is always the old (pre-action) path, which indicates that Mp3tag doesn't notice it has moved the files to the new folder.
Maybe the latest Development Build fixes the problem. If not, please provide the exact directory structure, so that I can reproduce the problem step by step.
The problem I initially reported seems to be fixed now. But after applying the options, shouldn't Mp3tag switch to the new folder automatically? Because as of now, pressing the refresh button right after applying any of the actions, shows that Mp3tag is still looking in the old folder.
The problem with this is that after applying the action, the tracks are still listed, so the user might think he can still perform modifications to the tags. Even the "Directory:" field in the Tag Panel changes to the new value, but Mp3tag isn't really looking there. Just press "Refresh" and you'll see.
If you could make Mp3tag look in the new path after renaming/moving a folder, we can say this is fixed!
