F3 calls up the Filter bar putting the focus is on some invisible control on the bar, rather than the Field - the first visible one - as expected. And there's no way to move it ti 'invert' - TAB takes it around Field, Filter and this invisible control, only.
This "invisible control" is the file view (just press the arrow-down key to select the first file).
I'll fix the tab order to the next release. Thanks for reporting!
Coo... so it is. I see no focus indicator, and the filelist selection highlight disappears. I can't see the advantage of Filter bar opening doing this move of the focus within the filelist.
Tag Panel opening moves it to the Tag Panel. I suggest it would good for Filter bar opening to do likewise.
Thanks. You could also add Filter: and invert: keys! ![]()
You're welcome!
Actually I've just noticed the Field: key doesn't work. I.e. with Filter: in focus, ALT+i doesn't go to F_i_eld.
Fixed the tab issue with Mp3tag v2.40. Shortcut keys will be added with the next release.
Confirmed i.e. that the tab sequence now includes invert.
Added mnemonics with Development Build v2.40a.
