If you use to open the tag panel, then to navigate to the "Title" field, then use to hide the Tag Panel, you have to hit tab 11 times to return the focus to any visible controls.
Pressing one time [Shift]+[Tab] set the cursor to the first line in file view.
But you are right.
The focus should be set to the list view automatically after closing the panel.
Didn't we have already asked for this and wasn't it already implemented to this?
DD.20100301.1922.CET
Good point! I'll change it to the next release.
Kind regards,
Florian
This is now fixed with Mp3tag v2.46.
