A column with %_folderpath% in 'Field:' refuses to be edited i.e. is read-only in the tracklist.
Help says:
Field
This field is optional. The placeholder of this field is used for editing the content of the field through the file view - if this field is empty, the column is write protected.
You can use placeholders for tag fields, %_filename_ext%, or %_filename% here.
One fix to the problem would be:
You can use only placeholders for tag fields, %_filename_ext%, or %_filename% here.
