e.g.
C:>start "" "%PROGRAMFILES%\\Mp3tag\Mp3tag.exe" /fp:"C:\nosuchdir"
loads all the tracks on Q:! This can be dangerous.
e.g.
This is a duplicate of this already confirmed bug reported by yourself.
That "causes Mp3tag to hang at "Reading directory":" This one does not - it causes wrong tracks to be loaded.
It's the same case. In the case where you thought Mp3tag was hanging, the process to examine all files on the partition simply took a little bit longer.
I am surprised because in the hang case I detected no disc activity. But OK, thanks.
Should be fixed with the current Development Build.
Well on V2.43b "%PROGRAMFILES%\\Mp3tag\Mp3tag.exe" /fp:"C:\nosuchdir" was silent for a minute or so then loaded all the files from C:! So, though the drive is different, I think this is not a fix to the OP issue.
Yes, I can confirm this and changed the status of this bug report accordingly.
Confirmed fixed in V2.44. Thanks.
