[F] Help correction?
In the Help-description Menupoint
File -> Options -> Mpeg -> chapter Write
is to read:
ID3v2 if enabled, Mp3tag writes an ID3v1 tag to the file.
Do You agree, it should be corrected to:
ID3v2 if enabled, Mp3tag writes an ID3v1 tag to the file and an ID3v2 tag to the file.
:book:
Best regards
John
No.
Correct:
ID3v2 if enabled, Mp3tag writes an ID3v2 tag to the file.
To be sure I have understand the aspect fully correct:
is to read:
Best regards
John
Yes.
ID3v1 if enabled, Mp3tag writes an ID3v1 tag to the file.
:slight_smile:
I'll correct it to the next release.
The answer shows, how stringent logical the thinking is in this program. Many program attempt (in a good meaning) to "think for the user" and do, what it think, should be the best for user - but it never knows, what the individual user really want in an actual case! In short: In this program You are the "driver" yourself. Brilliant thinking! :slight_smile:
