[F] Help error - bitrate
https://docs.mp3tag.de/export says
Technical info
%_bitrate% Bitrate
whereas in fact %_bitrate% returns the bitrate divided by 1000.
My suggestion would be to change the help file to "Bitrate (in kbps)" and leave the placeholder return value as-is (otherwise you might break people's scripts).
Sure, I've already changed it.
Agreed.
Fixed with Mp3tag v2.41c.
