Using the attached incorrect script causes crash. Problem with the [#x].
It works without problem after changing [#8] to [#2].
This sample script doesn't do anything useful, but this is just a sample.
Portable.mta (99 Bytes)
Fixed. Thanks for reporting!
Thanks for fixing.
You are the best, Florian. And Mp3Tag is the No. 1 in tagging obviously.
