in the Tag-Filename window with version 2.38.
I wanted to use it like this:
$if($eql($len(%_length%),8),$replace($mid(%_length%,2,2),_,h)$replace($right(%_length%,5),_,m)s,$replace(%_length%,_,m)s)
for converting 1:03:08 to 1h03m08s.
Strange subject, %_length% works fine for me
Thank you for the reply.
It worked fine for me with the version of 2.37a or below, but 2.38..., no.
For some reason, %_length% doesn't work in the Tag-Filename converter; at least not with my FLAC files. It works in the file grid, though.
Anyways, why are you replacing underscores with h, m and s instead of colons?
Colons are automatically replaced with underscores by Mp3tag in the Tag-Filename converter.
So I am re-replacing them.
Thank you.
%_length% is back
It works fine now with 2.38a.
Thank you very much!
