.M4a files are detected by the program but not handled correctly..
SYMPTOMS.
Changing an element of a files tags will randomly erase other elements.
For example changing the title will remove the track number and year.
Changing the track number removes the title.
This applies to all functions in the application such as:
Manually changing tag information for .M4a files in the list or Tag Panel.
Using FreeDB to select and change file names automatically.
Using any of the Convert menu functions.
It applies to changes of multiple or single files.
For many of the functions the results are hit and miss with tag data getting lost at random or simply not getting saved at all.
WORKAROUND.
Change the file extensions to .AAC.
As soon as this is done all of the above symptoms are corrected.
(1) I try the application on a .m4a file created in itunes (for example using convert to AAC). Changing tags in Mp3tag works fine.
(2) Some of the other files were created using dbpowerAmp Music Converter. Specifically the following codec .m4a (FAAC CLI). THESE FAIL as above.
So it looks like the encoding method.
I am using Quality 70 VBR.
I am going to email you a file that does not work and is encoded in this way.
Incidentally if I should not be using this codec or Variable Bit Rate could you let me know the reasons why not. VBR seems to give me more bang for my buck in terms of quality and file size than regular itunes.
Still I really want to use Mp3tag as I have a lot of Audio CD's to get on my new Ipod.
I have got a kind of work around, as a short term thing using lossless transcoding.
I extract my CD's as monkey audio a lossless codec. Then I can tag without issues in MP3Tag. I then convert the monkey audio file into the finished VBR .M4A format which carries all the tag information into the finished file.
Sounds a lot of work but it is mostly automatic with dbpoweramp and I don't actually change the quality of the music until I switch to .m4a.
Basically I am just using monkey audio to give me a lossless format that I can tag.
I can do the same with Wavepack files which tag beautifully prior to converting to cbr m4a.
After which, running any conversion or changing say the date field, causes MP3Tag to act in a very peculiar manner.
Very sorry!
I misguidedly thought that I was confirming that the "bug" was manifesting itself in cbr files.
I understood that the other posts referred to vbr files.....
No intention to increase the confusion here further.
I just want to add that MPEG4-AAC ripping into MP4 containers (.m4a extension) works beautifully in all recent Mp3tag versions with a combination of Exact Audio Copy, NEncode and Ahead's Nero Digital (also in VBR mode!). So maybe this is useful information for you.
