I am unsure if this is a bug or if I just do not know what I am doing. If I am editing a Flac tag in the main panel and hit 'Enter' it moves to the next file, B, as it should, but if I then select a group of files, the detail panel does not display the correct information for the selected files; it shows data for file B and, if I do not notice this, all my selected files will have their tags changed to be the same as those in file B. To have this not happen, I have to first move away from file B before selecting the group of files. If possible, selecting one or a group of files should automatically update the data in the detail panel.
thanks for a great piece of software.
