with the latest release 2.37d the md5 is not exported; instead is written to the file
I'm work with %_crc%, but when update to version 2.37d, only obtain
Thanks ![]()
In my version of 2.37d it looks like:
_crc ..................: <ERROR>
_md5 ..................: <ERROR>
_md5audio .............: <ERROR>
DD.20070131.0920
any news about it?
Thank you, it's looking all good.
_volume .................: MEDION
_parent_directory .......: Air
_workingdir .............: Air
_workingpath ............: O:\MUSIK\A\Air\
_path ...................: O:\MUSIK\A\Air\Talkie Walkie\06_SurfingOnARocket_Air_TW_2004.mp3
_folderpath .............: O:\MUSIK\A\Air\Talkie Walkie\
_folderpath_rel .........: Talkie Walkie\
_directory ..............: Talkie Walkie
_filename_ext ...........: 06_SurfingOnARocket_Air_TW_2004.mp3
_filename ...............: 06_SurfingOnARocket_Air_TW_2004
_filename_rel ...........: Talkie Walkie\06_SurfingOnARocket_Air_TW_2004.mp3
_file_create_date........: 09.01.2007
_file_create_datetime....: 09.01.2007 12:43:30
_file_create_datetime_raw: 1168343010
_file_mod_date ..........: 09.01.2007
_file_mod_datetime ......: 09.01.2007 13:41:12
_file_mod_datetime_raw ..: 1168346472
_file_size ..............: 7,35 MB
_file_size_bytes ........: 7703757
_file_size_kb ...........: 7523,20
_file_size_mb ...........: 7,35
_crc ....................: 9C34FC2E
_md5 ....................: 73A12D7B2F9FC6BC97AD7E25747985FD
_md5audio ...............: 344CF003323427A90FE178CB3492A30C
_bitrate ................: 275
_codec ..................: MPEG 1 Layer III
_length .................: 03:43
_length_seconds .........: 223
_mode ...................: Joint Stereo
_samplerate .............: 44100
_tag ....................: ID3v1 ID3v2.4
_tag_read ...............: ID3v2.4
_tag_size ...............: 20868
_tag_size_appended ......: 128
_tag_size_prepended .....: 20740
_vbr ....................: VBR
_covers .................: 2
_cover_mimetype .........: image/jpeg
_cover_size .............: 10142
DD.20070215.2350
Many thanks Florian for fixing this ...
I'll give it a try asap.
QUOTE (DetlevD @ Feb 16 2007, 08:50) <{POST_SNAPBACK}>
DD.20070215.2350
I have added columns with these values. Only the bitrate is displayed. All the other hash fields are empty. What else do I need to do to have the MD5 values displayed?
UPDATE: Cancel that last call. The values appear in the export (but not in the list view). The job is done though. THanks
