Steps to reproduce:
- select several tracks that do not have track number (checkpoint: Track field in tag panel should be empty)
- run wizard to generate track numbers
empty track value in tag panel is not replaced with ""
- so if you then specify e.g. album title and press Ctrl+S album will be saved but generated track numbers will be lost - will have to run wizard again
Mp3tag 2.36d
