abdsea
1
I tried to create automatic playlist using CTRL + SHIFT + P and used the following as options
%_folderpath%\%album%.m3u
I was playing with it to find how it works. The files loaded were in a directory using structure
%artist%\%album%\%title%.mp3 and I was hoping it would create a m3u files as %artist%\%album%\%album%.m3u.
The folder had four directories and the program successfully for 3 and missed the last one.
Thanks
N
PS: I had the view was sorted in Album column in ascending order.
Do you have the option Don't create directories enabled at Options > Playlist?
abdsea
3
Yes. I do have that enabled.
Florian
4
This bug has been fixed with the current Development Build.
Thanks for reporting!
Best regards,
Florian
abdsea
5
Thank you for your speedy response. I will test it out update.
N
abdsea
6
Awesome. It works as expected.
Thanks again N
Florian
Closed
7
