Hello,
In documentation the page "/help/options_tags.html" is missing a link to the page "/help/main_mapping.html".
Also, in the latter the page title and the breadcrumb seem incorrect (confusion "Options"/Configuration" and more notably missing links).
Regards
Florian
2
Hello Bertrand,
thanks for pointing – I'll correct that for the next release.
Kind regards
– Florian
Thank you
Also, I just noticed the breadcrumb in /options_advanced.html is wrong. It should be "Configuration > Tags > Mapping".
Hi Bertrand,
thanks — I've corrected the breadcrumb
Kind regards
– Florian
The reported issues are now fixed with the current Development Build (Mp3tag v2.80a).
Thanks again!
Kind regards
– Florian
Florian
Closed
6
