[F] MKV - Right Click menu in Windows Explorer
bug-fixed
#1
Having the mkv support in 2.84b is a great addition
Could we have the right click option in explorer please to launch Mp3Tag for a MKV file please as changing directory to open a mkv file is a bit tedious - i guess its an omission rather than a bug
#2
Great! If you find time to test it, I'd greatly appreciate your feedback.
Yes, absolutely. I'll add it to the next release. In the meantime, you can try drag'n'drop — it's pretty fast too.
Kind regards
– Florian
#3
Great - that will be 2.84d as it does not appear to be in 2.84c
:smiley:
#4
Expect it to be in v2.85 at the latest :slight_smile:
Kind regards
– Florian
closed #5
