not a major bug, but kindof a pain in the butt as I always have to correct this mispelling for the music genre.
Also, is there a way to stop "Psychedelic Rock" from popping up when all I want is "Psychedelic"?
I'll change it to the next release.
You can disable auto-complete at Options, General but this will also affect all other input fields.
Best regards,
~ Florian
This should be fixed with the latest Development Build
Best regards,
~ Florian
