Thread split from here
i discovered this: if you "undo" (ctrl+z) an action or a renaming there is no auto refresh
Dano,
there are two window parts in Mp3tag which can be refreshed (or even not). The first is the Tag input mask and the second is the file view. Can you please be a little bit more specific, which one (or even both) are not refreshing after an undo operation?
Best regards,
~ Florian
the left one with the tag fields "Tag input mask" i guess.
the refreshing of filenames seems to be ok
This should be fixed with the latest Development Build.
Thanks for reporting
Best regards,
~ Florian
