When I looked at how my column display information changed as a result of the tag name changes, I noticed that my ITUNESCOMPILATION column had been remapped to %podcast% instead of %compilation% as indicated in the release notes.
odd. mine too. (the field name in the custom column definition)
+1
And the ID 3v.2.3 frame TCMP is now automatically mapped to MP3Tag name Compilation and not visible in the advanced tag window or to my scripts used to change the file name/file path. ![]()
Many thanks for pointing! The incorrect mapping will be fixed with the next release, although you have to change it manually if you used v2.46d.
