I am not sure if it's a problem but the "saving configuration" utility seems to create a mp3tag.reg that has some problem:
All the strings key are not saved as string but only the 1st charater is saved as it's ASCII code and the rest of the string is lost
Example:
Actual Registy key:
"ConvTTF"="$if($not(%artist%),,%artist% - )$if($not(%album%),,%album% - )$if($not($num(%track%,2)),,$num(%track%,2) - )%title%"
is saved as
"ConvTTF"="36" (36 is ASCII code of '$')
This seems not related to the last V2.32t version.
Dom.
dano
2
I think this is a real bug. Introduced probably with the unicode builds.
My 2.32t has the bug.
This bug should be solved with the current Development Build.
Thanks for reporting!
Best regards,
~ Florian
thanks for this quick fix.
This was more anoying than creating a real problem (always painfull to retype the different options I have
continue to keep this great utility alive!
Best regards,
Dom.
Florian
Closed
5
