[F] Small bug
  1. Load a dir, select all files (STRG+A)
  2. Open another dir via explorer context menu or CTRL+D
  3. Notice in the Tag window, all stands on < beibehalten > and you need to click on 2 files to get the tag view
    If you refresh a dir which you just deleted, the Tag window won't really refresh.
Thanks, I'll fix this to the next release.
I think this is ok.
Will it be fixed?
It's already fixed since some Development Builds.
OH, i see, but Strg+D is not
Thanks, I forgot this one - will be fixed in a few seconds.
~ Florian
Thank you!
