I'm using v 2.32 and there is no Mp3tagError.log in the data directory.
I'm working with aac files.
Open a directory, select a file. File has and displays in the edit area all tags except year. Edit year and save. Title tag is now empty....?!#?%
Now select menu Convert/Filename to tag. With correct format string (%artist% - %track% - %title%), execute. Year tag is now empty....?!#?%
This is a great program, usually -
Thank You
Can I get a link to the last version, please?
...found an old version on Tucows...
After installing the previous version, it looks like this is a display problem in the prog. The tags actually contain the correct data, the (new) prog just won't display these values simultaneously....
hope that helps
Please attach a screenshot of the Options, Tags, Ape/Mpc... options dialog page.
Best regards,
~ Florian
On that options panel, the only item NOT checked is Remove ID3v2. Of course, I'm back using the previous (working) version...
I've marked this report as "No Bug", because I can't reproduce it and no other user reported any issues like that.
~ Florian
This version is still having this problem. It would go away if I reinstalled, but is back and will not go away.
I am only working with m4a files, maybe that is why there are no other reports.
This problem is 100% reproduceable...
Further investigation may point the problem at the new QuickTime 7 pro. I'll keep you updated. Sorry for the confusion...
The report is marked as open again.
Please send me one of the affected files and I'll try to reproduce it.
Best regards,
~ Florian
This bug will be fixed with the next Development Build.
Best regards,
~ Florian
This should be fixed with the current Development Build now.
Best regards,
~ Florian
