Here are the steps I'm doing to get that bug.
I select all the files I need to look for with Freedb.
I go in the "Tag Sources" menu, "freedb..." submenu and the "determine from selected files" option.
That's it. I'm getting a Runtime error message for the mtmainframe C++ source file.
So do I..
When I use a freedb function, following error happens;
Runtime error
File: .\mtmainframe.cpp
Line: 2295
thanks for good tool~
Florian
February 17, 2007, 6:16pm
4
This bug has been fixed with the latest Development Build .
Thanks for reporting!
Kind regards,
Florian
Florian
Closed
December 28, 2018, 1:55pm
5
