Hi there.
I have version 2.38c, but have tried with earlier versions also. Every time I start mp3 tag, I get the following error: (look at attached picture)
Any ideas.
ps. the errorlog file is empty...
Hi there.
Any ideas.
This is really an interesting error message.
Are you running Mp3tag from a special device or does your user account has some special way to store the profile?
Kind regards,
Florian
It's on my laptop. I ran it on my desktop on vista 64 with no problems. I think it is due to a security issue. I will reinstall my computer since it's acting strange.
I home you can use it to create better error handeling. ![]()
Thanks for the BEST mp3 utility in the world
Thanks for your fast response!
Can you please install this modified version and post the contents of the message boxes that will appear after starting the program?
You can simply press [Ctrl+C] to copy the contents of the message boxes to the clipboard.
Thanks!
Florian
Edit: modified URL
Hi, I also get the same error, here is the info you need :
C:\Program Files\Mp3tag\
c:\
\mp3tag\data\
Schwerer Ausnahmefehler
Datei: .\sfilesystem.cpp
Zeile: 311
Term: _S_TRUE(bRetVal)
Code: 00000000
Die Anwendung befindet sich in einem undefinierten Zustand.
Schließen Sie die Anwendung und übermitteln Sie die
Datei
\Mp3tag\Mp3tagError.log
sowie eine möglichst genaue Beschreibung der Fehlerentstehung
an den Support.
many thanks for your help.
Jason
Awesome, it works like a dream! Thank you very much !
This bug is also fixed with Mp3tag v2.39.
Kind regards,
Florian
