Anyone know why formatting a field to {$char(&H200C)} http://i.imgur.com/5bPFE8W.png gives just { http://i.imgur.com/npWz9uU.png ?
Same results with other zero-width Unicode characters.
And how to workaround this?
Thanks.
Thanks.
Please load up pictures directly together with your board message to the Mp3tag server.
I dislike to connect to foreign servers.
You want to use the unicode character ZERO WIDTH NON-JOINER.
http://en.wikipedia.org/wiki/Zero-width_non-joiner
Hmm, do you think that this is the correct syntax $char(&H200C) in Mp3tag?
Indeed it does work with $char(8204).
Try this formatstring ...
'Mp3'$char(8204)'tag ### '$len('Mp3'$char(8204)'tag')Using the OpenOffice font "Unicode Symbols", or some other full unicode font, you will see the text "Mp3tag" with a length of 7 characters.
DD.20140825.0952.CEST
Oops, my mistake.
That works here too. Thanks D.
