Every attempt to play a FLAC fails with e.g.
. Cannot open file "G:\file.flac" for playing!
even though play works fine when that filepath is pasted into Windows Run.
I'm sure not everyone can be finding this! So, can anyone suggest what's up here? Thanks.
Florian
2
Mp3tag reads HKEY_CLASSES_ROOT.FLAC for a reference to a file type that contains the default program to open the file.
Explorer File Types shows FLAC open uses Winamp. Isn't that all the info mp3tag needs? Or does mp3tag need me to create a registery key manually?
Which value has the entry at HKEY_CLASSES_ROOT.FLAC?
HKEY_CLASSES_ROOT.flac has the value flac_auto_file .
HKEY_CLASSES_ROOT\flc_auto_file\shell\open\command has
Name Type Data
(Default) REG_SZ "C:\Program Files\Winamp\winamp.exe" "%1"
Do you have Winamp installed in this location?
Yes.
If I paste C:\Program Files\Winamp\winamp.exe into Start | Run..., Winamp launches.
Florian
10
Do you have specified a tool for the default double-click action at Options > Tools?
chrisjj
11
No.
'Use special program at double clicks' is unchecked.
Florian
12
Can you please follow these steps:
- open Mp3tag
- select one FLAC file in the file list
- press Ctrl+Shift+F5
- double-click on the file to reproduce the behaviour
- press Ctrl+Shift+F8
- close Mp3tag
After that, please send me the file %APPDATA%\Mp3tag\Mp3tagLog.zip via email.
Thanks!
chrisjj
13
Impressive - esp. the sound effects!
You have mail.
PS FWIW the (only, so far) other mp3tag user I've asked to try this reports the same failure, also on WinXP SP2.
Edit: removed email address to prevent spam
Florian
14
According to the log it's not
but
C:\Program Files\GoldWave\GoldWave.exe
chrisjj
15
Oops, sorry my mistake - you asked for
but my <{POST_SNAPBACK}> gave you
There's no C:\Program Files\GoldWave\GoldWave.exe so since mp3tag is looking for specifically it, that explains the failure.
Leavng the question: how come this installation of mp3tag fails to launch FLAC whereas whereas other programs e.g. Explorer succeed?
Florian
16
I'll try to make that more reliable to the next version.
Kind regards,
Florian
chrisjj
17
Perhaps ShellExecute (http://support.microsoft.com/kb/238245) is a better way to go, giving the the job of app-finding to Windows. This might be good for /t/5529/1 a) too.
Thanks again Florian.
Florian
18
Yes, I think ShellExecute is the way to go.
Florian
19
I've changed the behaviour with the current Development Build.
Does this resolve the issue for you?
Kind regards,
Florian
