Failure to write BOM
I have Tools | Options... | Export, [X] Write BOM yet File | Export is not writing a BOM to .txt files. Any ideas?
What encoding are you using? -> $filename(test.txt,Encoding)
How do you know there is no BOM?
The default.
There no $filename in the config file.
Hex editor shows none.
Ok it seems if you do not use $filename() in your config you get no BOM.
Thanks for the confirmation.
