One of the functions I use a lot is "Create a playlist from all files", for me it would be nice if there was a second icon that would "Create a playlist from all files and remove all files from the window". I know I can press Ctrl+A to select all and then hit the delete key but when I'm doing this for 50-100 folders it gets to be a time saver and helps eliminate hitting the wrong keys and creating undesirable actions.
Why do you remove all files from the window?
When you add files to Mp3tag the current files are automatically removed.
AH...... I did not know this. This is exactly what I wanted. Thanks!
